Home > Td5 > Drivers door popping open
excossack
Recently the drivers door popped open while driving along the road, so I adjusted the striker on the door frame and the door shut better. If I pull on the door when shut or push from the inside with my shoulder the door does not open. But still while driving along the door randomly opens - not to the point where the door is swinging in the wind, its still on the latch but ajar.
Striker?
Door lock/catch?
Auto ventilation at speed or automatic water dispersal system?
No central locking 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #817079 26th Feb 2020 5:34pm
donmacn
when mine was doing this (round corners, roundabouts) it was the striker - the nylon covering had worn away and I guess the door wasn't latching properly.
Water dispersal system... Laughing Laughing there have been times I could have used one of them! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #817091 26th Feb 2020 6:24pm
grafty99
A long time ago, my 90 used to do the same on the passenger side but only in cold weather. It sometimes took a few slams for it to actually stay closed. A through dose of spray lubricant in the latch sis the trick Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #817094 26th Feb 2020 6:43pm
landy andy
Wash the latch mechanism with brake cleaner. It sorted mine. Think it’s due to too much oil, and it being too thick as it’s cold.
Post #817119 26th Feb 2020 9:00pm
excossack
Cheers chaps. I have ordered a new latch as well. Sounds like tomorrow is squirting time. 1999 Defender TD5 110
Regards
John M0VAZ
Post #817140 26th Feb 2020 10:14pm
MGCarr
United Kingdom 1997 Defender 90 300 Tdi PU Rioja Red
I tried all the usual things on my 90’s drivers door and the only permanent fix was a new door latch.
Post #817145 27th Feb 2020 12:31am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Used to happen to me when I was trialing in my 80 many years ago Rolling with laughter
Post #817185 27th Feb 2020 9:40am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Hard seals in the cold can cause bounce back on the doors before the latch can lock, passenger side on mine does this at the moment on cold mornings, drivers side is fine though!
Last winter I was prepared and lubricated the seals with silicon spray and the locks before the cold weather set in and had no problem. This year I wasn't so well organised Rolling Eyes
Post #817200 27th Feb 2020 11:04am
excossack
Thanks for the suggestions. I have also ordered a new door catch as well - remembered why I don't use the key to lock the door....its a bit stiff. 1999 Defender TD5 110
Regards
John M0VAZ
Post #817202 27th Feb 2020 11:23am
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Post #817279 27th Feb 2020 8:43pm
excossack
Cheers. I forgot about them! Ordered a new lock and catch which have arrived. Getting fed up no of the door popping. 1999 Defender TD5 110
Regards
John M0VAZ
Post #817581 29th Feb 2020 6:53pm
excossack
Replaced the striker plate and the door lock and so far the drivers door has stayed shut while driving, which is an improvement over recent days!
However the word was not without its challenges;
I needed to find a spare shim for the striker plate.
Weld a crack around the door push down internal button.
Fix a rusted strengthener piece that runs across the inside of the door.
Replace the weather sheet behind the door card.
After replacing the door lock and testing as I went. I thought all was well. Put the door back together and put the tools away. Only to discover that once the door was shut the outside push button would not open the door Sad
Called it a night.
Sunday had another look, dismantled the door and discovered the rod for the push button linkage had come out the hole it fits in.
Looking at the pics on my phone I had missed out a rattle clip. Found said clip and then reinstalled the clip - all good. 1999 Defender TD5 110
Regards
John M0VAZ
Post #818929 9th Mar 2020 4:49pm
excossack
The issue of the door popping open is resolved Smile
How ever now, the drivers door wont open on the key without excessive effort of turning the key. Sad
Looks to be like the barrel needs to turn further than the mechanism will allow. 1999 Defender TD5 110
Regards
John M0VAZ
Post #819742 15th Mar 2020 12:40pm
fred2000
Australia 2000 Defender 130 2.5 TD HCPU Alaska White
drivers door popping open
All good suggestions, when my door came open whilst driving, it was due to the hinges being badly worn. Being the tight ass I am I drilled out the pins and made new ones. I can tell you they are tough to drill. Installed and door was again snug as a bug in a rug!
Post #820164 18th Mar 2020 9:20pm
Landish
United Kingdom 2005 Defender 90 Td5 SW Belize Green
The driver’s door on my Td5 popped open and swung wide while I was driving last week so I just grabbed the handle and gave it a good slam. When I got home, I couldn’t open the door from the inside - so I thought I’d get out of the passenger door but I initially found I couldn’t move because my coat was caught in the latch. By this time, my wife was watching and laughing. Anyway, I wriggled out of my coat, climbed over and left by the passenger door. A good yank on the door from outside solved the problem and I retrieved my coat but not my dignity . . . .
(Happy to give you a bit of a laugh in these difficult times) 2005 Defender 90 TD5
Post #820596 22nd Mar 2020 7:43am
