Home > Technical > Battery charging time
ericvv
Good evening,
I have a standard genuine battery in my Puma, a new one since two or three years ago if I remember well. In the beginning if I occasionally connected my MXS5.0 charger to it, it would fully charge the battery in about 1 hour or so.
These days, leaving the truck rarely used in the winter it is quite different. The charger will fully charge the battery, which then will show about 12.5 V when checking a day later. In about a week at rest the voltage will have dropped to 12.3V which guess is not too bad. But what I can’t understand is that the MXS5.0 will now need about 6 to 8 hours charging time before showing that battery is full. Sounds long to me, don’t really understand. Truck is electrically very standard, no electric guzzling gimmicks added. If I decide to use it before recharging after a week of inactivity, no sign of a weak battery at all. Any explanation why I have these long charging times in the normal car charging mode on the MXS5.0?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #816761 24th Feb 2020 6:39pm
Bluest
If it’s not connected to anything, I’d expect the fully charged resting voltage to remain higher than 12.3v 2007 110 TDCi Station Wagon XS
Post #816762 24th Feb 2020 6:41pm
dorsetsmith
spec for your battery and charger - for 110Ah battery 26hr for 80% charge state down to 20c-
Post #816763 24th Feb 2020 6:49pm
ericvv
Spec for my battery is a Varta 90Ah. The same as the factory installed one. The charger is the Ctek MXS5.0, so should charge at upto 5Ah. I just don’t understand why charging from 12.3V back up to 12.5/12.6V now takes 6 to 8 hours. I know the Ctek won’t charge continuously at 5Ah during that period, but still it seems long to me.
Post #816786 24th Feb 2020 8:22pm
ARC99
I regularly charge up the 110amp batteries for the caravan, I noticed when I switched from a "normal charger" to a Ctek that it took longer to reach fully charged. The explanation I have been given is that the Ctek senses that the battery is almost fully charged and backs off so not to boil the battery. Don't make old people mad.
Richard
Post #816843 25th Feb 2020 8:35am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
I think this is normal behaviour for the CTEK. I have the same charger as you and also noticed that it takes longer to charge from 75% full than from 50% full. I haven't taken voltage readings though, just going from my guesstimate of battery charge.
I also leave the charger connected for long periods and the charger goes into "maintain charge" mode with the final green light coming on.
Don't think you have a problem if the battery seems ok when starting.
Stephen
Post #816847 25th Feb 2020 9:16am
