![]() | Home > Puma (Tdci) > EKA - programable with nanocom? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1809 ![]() ![]() ![]() |
Does anyone know if the Emergency Access Code can be re programmed wih a Nanocom?
Thanks Keith |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
No
The code is given not programmed Mike |
You can read it and change it......
but if you change it the engine will not run, because the code must be match with the (virtually the same) code stored inside the engine ECU, and Nanocom Evo cannot change it........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
yet
