Home > Puma (Tdci) > EKA - programable with nanocom?
ickle
Does anyone know if the Emergency Access Code can be re programmed wih a Nanocom?
Thanks Keith
Post #76884 20th Jun 2011 8:43pm
mse
No
The code is given not programmed Mike
Post #77027 21st Jun 2011 5:33pm
dgardel
Italy
You can read it and change it......
but if you change it the engine will not run, because the code must be match with the (virtually the same) code stored inside the engine ECU, and Nanocom Evo cannot change it........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #77055 21st Jun 2011 7:49pm
bell-auto-services
yet Thumbs Up
Post #77211 22nd Jun 2011 9:08pm
