![]() | Home > Technical > Stuck in 3rd gear, now in neutral can’t select any gears.. |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 ![]() ![]() ![]() |
Clutch spring let go and stuck against flywheel ?
dba11 Member Since: 12 Feb 2014 Location: St Jory de Chalais Posts: 26 ![]() ![]() ![]() |
Ooh, hadn’t even thought of that 😲
I had a new updated heavy duty clutch fitted in October 2018, so would hope it’s not that, but another one to put on the list to rule out. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17622 ![]() ![]() ![]() |
If it was the clutch you would still be able to select gears with the engine stopped.
Thanks black wolf, will cross that off then.
I think I will dismantle gearstick assembly again and try and move the selector rail forward and backwards and see if it makes any difference. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1833 ![]() ![]() ![]() |
Hopefully you'll sort it, but if you have probs I've a good 50k box sat in the barn that I bought and didn't need......
Keith |
Cheers Keith (ickle), I’ll bare that in mind depending on what I find.
