![]() | Home > Off Topic > Boris bans petrol, diesel, hybrids by 2035, 2032 ,2030 |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
National grid provide electricity transmission. Your local network operator deals with distribution and it is they whom you would need to speak to. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
That sounds extremely small. I would expect minimum 25mm2, these days it's almost always 35mm2. The incoming voltage fluctuation is likely either a fault on the cable or something back up the supply chain. Transformer breaking down, trees in line etc. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Bian Considine Member Since: 25 Jul 2020 Location: Margate Posts: 53 ![]() ![]() |
100 amp ! (I checked when my meter was replaced). |
Goodness. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
Government looking at E highways for road freight.
https://www.theguardian.com/environment/20...says-study Link to the paper in article. WARNING. This post may contain sarcasm. |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2664 ![]() ![]() ![]() |
With all the U turns of recent by the time we get to 2035 I think we will be back using horse and carts and velocipedes by then.
I read that article and thought it was an excellent idea, in theory, but can't see it working in any real world environment. If you extrapolate from the number of bits of shredded artic tyres you see on major routes to pantograph maintenance, I shudder to think of the length of overhead line that will be being brought down on a daily basis. |
You need to contact your local network operator, not whoever you pay your bills to. Sounds like you live in the UKPN region but pay to EDF? Assuming that's correct, UKPN would be responsible for the meter and everything going into the house/switchboard area (not by area of expertees I will admit) and UKPN are responsible for the cable in the ground/up the poles. So you need to contact UKPN. I'd be worried having such tiny cables as you describe with a 100A fuse! Easy to overheat such a setup. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Roger Member Since: 26 Apr 2018 Location: Hampshire Posts: 71 ![]() ![]() ![]() |
I thought a "brown out" was when you didn't get to the toilet in time! ![]() |
Read through that - be interesting to see how they intend to keep the pantographs in contact with the catenary wires ? Unless the pantographs are a marketing gimmick so that we won't think they have re-invented the trolleybus. Of course, they could link all the trucks together, remove the tyres, put some small girders down & hey-presto - all fully guided. But wait, we already have them - called railways...... |
You need to contact your local network operator, not whoever you pay your bills to. Sounds like you live in the UKPN region but pay to EDF? Assuming that's correct, UKPN would be responsible for the meter and everything going into the house/switchboard area (not by area of expertees I will admit) and UKPN are responsible for the cable in the ground/up the poles. So you need to contact UKPN. I'd be worried having such tiny cables as you describe with a 100A fuse! Easy to overheat such a setup.[/quote] As I stated UKPN will not do anything because "I don't have a contract with them". Which I don't - we have a contract with EDF. EDF themselves fitted the fuse, installed 25mm2 meter tails and the meter which clearly states it is their property and their responsibility on it. All of this is documented & EDF have been informed in writing that they will be held responsible should any incident arise by their failure to insist that their sub-contractor UKPN to rectify the situation. As for the risk, the mains equipment is in a 1 hour rated enclosure complete with smoke detector connected to a BS5839 installed & maintained fire alarm system. Also, there is a maintained CO2 fire extinguisher to hand. TBH, we don't actually draw a lot from the grid as we have a 4kW solar panel array and a power vault. It's just the yo, yo voltage that is a problem. If all else fails then I run the 4.5kV generator ! |
Interesting to read about UKPN, where I live the network is maintained by Northern Powergrid. I've had no problem calling them out to a telegraph pole in my garden and they were more than happy to undertake remedial works. I dealt with them direct and there was never a mention of contracts.
Well obviously something is amiss here. It sounds like EDF are your electricity supplier and UKPN are your DNO. You won't have any kind of contract with UKPN. When you talk about small cables I assume you mean the ones coming into your home from a cable in the road or up a power pole nearby. In which case they are UKPNs responsibility.
In terms of contracts with UKPN it would he like having a contact with your binmen, it just isn't done that way. If in doubt I would suggest you contact OFGEM as from what I've read here your setup sounds horrendous, especially as you seem to be saying the meter tails are bigger than your incoming supply cable. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Yes, OFGEM are my next step in my long running disputes with EDF (there are more than one).
It's an underground supply & AFAIK we are at the very end of the "leg"from the substation. BTW, I do have a "contract" with my "waste management and disposal technicians" - I tip them at Christmas & they take all of my rubbish (not just whats in the Wheelie Bin). |
