![]() | Home > Technical > Seat belt repaired - Legal? |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Probably been trapped in the door close latch several times, frayed, and then some cowboy has melted it to make the damage less obvious than frayed material. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
That needs to be changed for your own piece of mind
![]() 2008 SVX 90 2000 XS TD5 90 |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1312 ![]() ![]() ![]() |
Yep it is easy to replace yourself. You can get r a replacement from Exmor Trim or from Advanced Factors (forum sponsors).
Make sure to get the right belt for your vehicle. |
sconie Member Since: 10 Jan 2020 Location: Paisley Posts: 50 ![]() ![]() |
Thanks all, is there a serial number or part number I can identify on the belt so I can order the correct one?
I got this one
https://www.exmoortrim.co.uk/front-4-door-reel-buckle.html . but call them and check if it will fit your vehicle Genuine LR is about three times the price |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Tell me about it. I failed mot and got charged 3 times that price. Plus labour!!! ðŸ˜
