Home > Td5 > replacing power steering fluid
alexatnd
I've never changed the power steering fluid in the 8 years I've had Gertie, our original 110 TD5. Vurrently done 225K miles and she had 85K when we bought her.
Think it possbly might be a good idea to replace it given the colour of the stuff in the resevoir. What's the provedure for doing the above?
Rgds
Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #812166 27th Jan 2020 2:37pm
4RF RDS
Simplest and least messy method:
1- jack up the front end and put LR on stands
2- take cap off reservoir and siphon out fluid
3- turn ignition key to unlock steering wheel
4- turn steering side to side, full lock, then rest when on off side
5- siphon out more fluid
6- repeat until nothing remains to siphon
7- Refill, slowly do the same
8- then restart engine
9- slowly refill to proper level
Note: this method does not get it all out but most say about 80% or so?
Other method is to get a trusted garage to flush and fill the system for you. This will change 100% of the fluid. Thumbs Up
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #812175 27th Jan 2020 4:11pm
