Home > Td5 > replacing power steering fluid |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 932 |
Simplest and least messy method:
1- jack up the front end and put LR on stands 2- take cap off reservoir and siphon out fluid 3- turn ignition key to unlock steering wheel 4- turn steering side to side, full lock, then rest when on off side 5- siphon out more fluid 6- repeat until nothing remains to siphon 7- Refill, slowly do the same 8- then restart engine 9- slowly refill to proper level Note: this method does not get it all out but most say about 80% or so? Other method is to get a trusted garage to flush and fill the system for you. This will change 100% of the fluid. Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
27th Jan 2020 3:11pm |
