Home > Technical > Alarm sounding when starting, after periods of inactivty
Galyman
Scotland 2013 Defender 110 Puma 2.2 HT Aintree Green
Hello
Looking for some advice. I have a 2011 Tdci 90 with a dual odyssey battery system and a relay switch. The Defender does not get as much use as it should at the moment so can sit idle, without being started for a week or more at a time. When I do come to start it, and turn the ignition, an alarm sounds until it turns over. It is not the noisy alarm, it is a more high pitched sound which is not too loud. I would hope it is not battery related as I thought the odyssey PC1500s were amongst the best, and are only a few years old.
Post #810087 13th Jan 2020 6:37pm
kmac
When you turn over the engine the battery voltage drops so the alarm sounds as it thinks the battery has been disconnected.
Main battery must be losing charge - keep it topped or replace,
Post #810118 13th Jan 2020 8:40pm
Galyman
Cheers kmac.
Taking it out on an extended run tomorrow so will give it a decent charge. Will then turn over daily and see if the it is losing charge relatively quickly or just when left for long periods if time.
Post #810126 13th Jan 2020 9:04pm
rockhound42
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I had a similar issue and after lots of head scratching found a bad bulb causing a short and draining the battery quicker than normal, bulb fixed and no more problems still running fine on the same odyssey pc1500 5 years later
Post #811147 20th Jan 2020 11:53am
Galyman
Any tips for getting to the bottom of what was causing the battery drain?
Post #811370 21st Jan 2020 8:51pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
how old is the battery ? you could have a load test on it used to be free at Halfords just don't buy a battery there if you need one
Post #811841 25th Jan 2020 8:02am
landy andy
For your info
If you talk to Oddesy they will tell you to, at least once a year take the out of the system and give them a full bench charge with a quality charger such as a ctek charger.
It certainly helped mine when I did what was recommended
Post #811844 25th Jan 2020 8:32am
Galyman
Andydef90 - Both batteries are about 4 years old.
landyandy - will look at getting both of them charged up.
Post #811967 25th Jan 2020 8:53pm
nidge n
I have two Defender 2.2. One used every day, the other once a week at best. Both turnover quickly and start immediately. I get a alarm, often on both, sounds like a bird whistling ( no birds were harmed in the writing of this thread) is this the alarm to which you refer as I’ve often wondered what it is.
Post #812092 26th Jan 2020 9:02pm
kmac
The hard way - remove all fuses and start putting them back one by one whilst measuring if there is any draw on the batter
Post #812216 27th Jan 2020 7:51pm
Or one of the current draw tools from this thread:
https://www.defender2.net/forum/post810324...ley#810324
Post #812339 28th Jan 2020 6:07pm
Galyman
Hmmm, using the tool seems to be a less laborious option.
Post #816051 19th Feb 2020 8:02pm
Wow, that was an extended run.
Post #816069 19th Feb 2020 9:52pm
Galyman
Kind of lost track of time. Battery or batteries do need a charge. Any suggestions for a charger and whether it can be done in situ or better to remove them and charge indepently?
Post #816072 19th Feb 2020 9:56pm
Have a search for CTEK on here will find you a range of options; including some of the best kit for charging insitu.
Post #816096 20th Feb 2020 6:51am
