Home > Technical > Alarm sounding when starting, after periods of inactivty |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
When you turn over the engine the battery voltage drops so the alarm sounds as it thinks the battery has been disconnected.
Main battery must be losing charge - keep it topped or replace, |
13th Jan 2020 8:40pm |
Galyman Member Since: 20 Jan 2016 Location: Scottish Borders Posts: 92 |
Cheers kmac.
Taking it out on an extended run tomorrow so will give it a decent charge. Will then turn over daily and see if the it is losing charge relatively quickly or just when left for long periods if time. |
13th Jan 2020 9:04pm |
rockhound42 Member Since: 24 Jun 2015 Location: where Surrey meets Sussex Posts: 38 |
I had a similar issue and after lots of head scratching found a bad bulb causing a short and draining the battery quicker than normal, bulb fixed and no more problems still running fine on the same odyssey pc1500 5 years later
20th Jan 2020 11:53am |
Any tips for getting to the bottom of what was causing the battery drain?
21st Jan 2020 8:51pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
how old is the battery ? you could have a load test on it used to be free at Halfords just don't buy a battery there if you need one
25th Jan 2020 8:02am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5733 |
For your info
If you talk to Oddesy they will tell you to, at least once a year take the out of the system and give them a full bench charge with a quality charger such as a ctek charger. It certainly helped mine when I did what was recommended |
25th Jan 2020 8:32am |
Andydef90 - Both batteries are about 4 years old.
landyandy - will look at getting both of them charged up. |
25th Jan 2020 8:53pm |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 719 |
I have two Defender 2.2. One used every day, the other once a week at best. Both turnover quickly and start immediately. I get a alarm, often on both, sounds like a bird whistling ( no birds were harmed in the writing of this thread) is this the alarm to which you refer as I’ve often wondered what it is.
26th Jan 2020 9:02pm |
The hard way - remove all fuses and start putting them back one by one whilst measuring if there is any draw on the batter |
27th Jan 2020 7:51pm |
Or one of the current draw tools from this thread:
https://www.defender2.net/forum/post810324...ley#810324 |
28th Jan 2020 6:07pm |
Hmmm, using the tool seems to be a less laborious option.
19th Feb 2020 8:02pm |
Wow, that was an extended run.
19th Feb 2020 9:52pm |
Kind of lost track of time. Battery or batteries do need a charge. Any suggestions for a charger and whether it can be done in situ or better to remove them and charge indepently?
19th Feb 2020 9:56pm |
Have a search for CTEK on here will find you a range of options; including some of the best kit for charging insitu.
20th Feb 2020 6:51am |
