![]() | Home > Technical > Earth points on bulkhead |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge |
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 ![]() ![]() ![]() |
Perfect Thanks you
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
MacFrank, do you by any chance have the same images as this one, for all the earthing points on a 2011 2.4 DCPU, or at the very least those that would relate directly to the headlight/side lights/indicators? It would be hugely appreciate. I have a dim Driver's side headlight when on dip (they're halo), and the two wonky lights when on main beam. When on main beam, indicator (specifically when turning right), doesn't work, only works on side lights. And the horning sounds like a fog-horn rather than a healthy toot. So bad, that I tooted some friends yesterday (they were walking) and they didn't hear me. ![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
What I can try is to lookup the related ground points in a 2012 wiring diagram (the connector shown above is also from a 2012 connector library, so hopefully they haven't changed significantly).
So: headlamps (main & dipped) and sidelights go to C0550 plug which has a ground point on the other end. That one is shown in the above image. Indicators: RH front & side --> C0550, too LH front & side --> C0550 also it seems Horn is also on C0550, so it seems this is a common denominator for your problems? LH & RH rear indicator --> C0558 on the side of the transfer box (probably not related to your problems; also connected to fuel pump, blower motor and the like) ![]() Click image to enlarge Ground point(s) on the engine side of the bulkhead go to the the ECU mounted there on TD4s, so some differences to the TD5 ground point diagram. |
Thanks MacFrank, that’s hugely useful. Fortunately I’ve got to get in behind the centre console to fit a new washer nozzle, so shall check the earth at the same time.
