Home > Maintenance & Modifications > Anyone know where I can get these plastic screws from?
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
The plastic screws which hold down the rubber tread on my nas rear step have faded and need replacing.. I ordered some M4 x 15mm replacements from fleabay but the button head is too small. I've not found any sort of genuine replacement when I've done a google so any help/advice pointing me in the right direction would be appreciated. TIA Thumbs Up
Post #810022 13th Jan 2020 11:44am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
They look like metal pan head screws with a plastic cover.
If so measure the plastic cover's width and depth and then do your search.
Sorry, but otherwise no idea.
Post #810027 13th Jan 2020 12:24pm
hank
Are they machine screws or self tappers? > 110 XS Double Cab
Post #810029 13th Jan 2020 12:33pm
X4CAC
They're little plastic screws which have a washer and nut underneath
Post #810036 13th Jan 2020 1:09pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Just an idea, but would black plastic number plate fixing screws work ?
Ashby Andy
Post #810056 13th Jan 2020 3:15pm
X4CAC
I didn't think of those... I'm sure I've got a bag lying around somewhere so will take a look.
Last resort might be to take them off and spray them i suppose...
Post #810058 13th Jan 2020 3:24pm
Ashby Andy
That's exactly what I used on mine:
Post #810062 13th Jan 2020 3:49pm
X4CAC
Thanks for the responses, I'll give that a go Thumbs Up
Post #810063 13th Jan 2020 3:50pm
UtilityTruck
The other option is spray paint- being plastic as long as it’s cleaned and degreased well it should stick OK. 2014 Keswick Utility 2.2
Post #810117 13th Jan 2020 8:28pm
Sulisuli
Would something like this work?
https://www.ebay.co.uk/itm/25-x-M8-Secure-...SwlptaPOqN 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #810119 13th Jan 2020 8:49pm
V8GPC
Post #810159 14th Jan 2020 6:33am
hank
Number plate screws are typically m6x20. Plastic ones will likely discolour again, as well as being low strength.
Personally I would fit black stainless screws with washers and nyloc nuts underneath.
Available cheaply on ebay, amazon etc. Just type in m6 black stainless pan screw, nut etc. The nuts and washers don't necessarily need to be black. Could use natural silver to make sourcing easier.
Bolt examples.
https://www.ebay.co.uk/itm/M6-J-I-S-BLACK-...2821936482
https://www.ebay.co.uk/itm/M6-6mm-BLACK-A2...1336240975
https://www.ebay.co.uk/itm/M6-BLACK-A2-STA...3640309607 > 110 XS Double Cab
Post #810160 14th Jan 2020 6:35am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
BTR3543PMD
Post #810317 15th Jan 2020 9:42am
X4CAC
Thanks but that looks like a plastic rivet, these are definitely screws which allow you to remove the mat for cleaning. I've ordered some from one of the links that Hank posted and see what they look like when they get here Thumbs Up
Post #810321 15th Jan 2020 9:52am
nicks
ok, though they looked the same as the ones on the discovery 1 rear bumper.
Post #810322 15th Jan 2020 9:56am
