Home > Maintenance & Modifications > Anyone know where I can get these plastic screws from? |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 730 |
They look like metal pan head screws with a plastic cover.
If so measure the plastic cover's width and depth and then do your search. Sorry, but otherwise no idea. |
13th Jan 2020 12:24pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2299 |
Are they machine screws or self tappers? > 110 XS Double Cab
13th Jan 2020 12:33pm |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 |
They're little plastic screws which have a washer and nut underneath
13th Jan 2020 1:09pm |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 223 |
Just an idea, but would black plastic number plate fixing screws work ?
Ashby Andy |
13th Jan 2020 3:15pm |
I didn't think of those... I'm sure I've got a bag lying around somewhere so will take a look.
Last resort might be to take them off and spray them i suppose... |
13th Jan 2020 3:24pm |
That's exactly what I used on mine: Click image to enlarge Click image to enlarge |
13th Jan 2020 3:49pm |
Thanks for the responses, I'll give that a go
13th Jan 2020 3:50pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
The other option is spray paint- being plastic as long as it’s cleaned and degreased well it should stick OK. 2014 Keswick Utility 2.2
13th Jan 2020 8:28pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Would something like this work?
https://www.ebay.co.uk/itm/25-x-M8-Secure-...SwlptaPOqN 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
13th Jan 2020 8:49pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
https://www.ebay.co.uk/itm/25-Black-Nylon-...3367076130
These come in M6 16mm to 35mm |
14th Jan 2020 6:33am |
Number plate screws are typically m6x20. Plastic ones will likely discolour again, as well as being low strength.
Personally I would fit black stainless screws with washers and nyloc nuts underneath. Available cheaply on ebay, amazon etc. Just type in m6 black stainless pan screw, nut etc. The nuts and washers don't necessarily need to be black. Could use natural silver to make sourcing easier. Bolt examples. https://www.ebay.co.uk/itm/M6-J-I-S-BLACK-...2821936482 https://www.ebay.co.uk/itm/M6-6mm-BLACK-A2...1336240975 https://www.ebay.co.uk/itm/M6-BLACK-A2-STA...3640309607 > 110 XS Double Cab |
14th Jan 2020 6:35am |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
BTR3543PMD
15th Jan 2020 9:42am |
Thanks but that looks like a plastic rivet, these are definitely screws which allow you to remove the mat for cleaning. I've ordered some from one of the links that Hank posted and see what they look like when they get here
15th Jan 2020 9:52am |
ok, though they looked the same as the ones on the discovery 1 rear bumper.
15th Jan 2020 9:56am |
