Home > Puma (Tdci) > Brakes Squealing!
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Brakes Squealing!
Morning Fella's
Anybody's brakes squeal? Mine squeal a bit when I lightly touch the brakes but stop when I increase the pressure.
Just wondered if it was the norm with defenders and if so any possible remidies other than WD40!
Luke
Post #76360 17th Jun 2011 7:33am
x-isle
Chances are, the squeel is actually the back of the pad and not the friction surface.
It vibrates inside the caliper and squeels against the piston.
Some pads come with a sticky rubber pad to stop it, if not, you can put a small amount of copper grease on the back of the pad...... Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #76361 17th Jun 2011 8:20am
Yup, mine scream like a banshee most of the time, it is loud enough to make people look round. I have tried all the conventional rememdies, and the sqeal always come back eventually.
They also rattle when not appplied as you drive along, and this too seems impossible to cure.
Post #76362 17th Jun 2011 8:34am
Tim_NZ
Australia
Only solution I found was a new set of pads Sad
Post #76363 17th Jun 2011 8:39am
DefenderOfTheEarth
Get occasional squealing but it's very quiet. Doesn't bother me. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #76367 17th Jun 2011 8:57am
haworthj
My offside front squeals occasionally. It's not bad, so it doesn't bother me, and also it's intermittent.
Post #76368 17th Jun 2011 9:06am
Jimbob
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
Yup, back passengers side always squeals and always has done since Ive had it. One of those things I think! 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader
2015 Defender XS Hard Top (awaiting delivery 😄)
Post #76399 17th Jun 2011 1:18pm
Lukey Boy
Looks like I'll try the cooper slip and if not put up with it. Dosn't really jar me off much just noticeable.
Thanks guys Thumbs Up
Post #76414 17th Jun 2011 4:47pm
