Home > Tdi > 300 tdi thermostat
spudfan
Ireland
300 tdi thermostat
Can anybody tell me where the thermostat on the Defender 300 tdi engine is? Heater is not putting out much warm air so I presume that the thermostat is stuck open. It happened to me on a 200 tdi but the 300 is new to me. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #808379 1st Jan 2020 4:37pm
Litch
Under here.
Just because the heater isn't giving full heat, doesn't follow that the thermostat is faulty (or even the wrong one has been fitted at some point).
Have you checked the heater control cables to make sure that the internal flap is closing fully and ensuring that all air is passing through the matrix and not around the sides? ONE LIFE, GET IT!
Post #808389 1st Jan 2020 5:40pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
now that's a tidy Tdi engine Very Happy Bow down Have fun be happy
Post #808398 1st Jan 2020 6:42pm
Oldowner
I remember when they all looked like that, the good old days!
Post #808409 1st Jan 2020 7:31pm
htb2
Wales
Auto as well.
Post #808424 1st Jan 2020 9:22pm
sako243
Does the engine get up to temperature? If so then it's more likely the issue is elsewhere. If the thermostat is stuck open or missing then the radiator will be cooling continuously and therefore the engine temperature won't rise as much as it should be. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #808431 1st Jan 2020 10:21pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Often they have been bled incorrectly in the past leading to poor heating, how hot are the pipes into and from the matrix? Air often gets trapped there reducing the heater output. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #808434 1st Jan 2020 10:41pm
spudfan
Ireland
Lots to check, thank you. The temperature gauge does not get to half way. Like I said earlier, I had the same issue with a 200 tdi and a change of thermostat resolved the issue. 1982 88" 2.25 diesel
Post #808435 1st Jan 2020 11:35pm
