Home > Tdi > 300 tdi thermostat |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4721 |
Can anybody tell me where the thermostat on the Defender 300 tdi engine is? Heater is not putting out much warm air so I presume that the thermostat is stuck open. It happened to me on a 200 tdi but the 300 is new to me. 1982 88" 2.25 diesel
1st Jan 2020 3:37pm |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 827 |
now that's a tidy Tdi engine Have fun be happy
1st Jan 2020 5:42pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 626 |
I remember when they all looked like that, the good old days!
1st Jan 2020 6:31pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 532 |
Auto as well.
1st Jan 2020 8:22pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1226 |
Does the engine get up to temperature? If so then it's more likely the issue is elsewhere. If the thermostat is stuck open or missing then the radiator will be cooling continuously and therefore the engine temperature won't rise as much as it should be. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
1st Jan 2020 9:21pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Often they have been bled incorrectly in the past leading to poor heating, how hot are the pipes into and from the matrix? Air often gets trapped there reducing the heater output. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
1st Jan 2020 9:41pm |
Lots to check, thank you. The temperature gauge does not get to half way. Like I said earlier, I had the same issue with a 200 tdi and a change of thermostat resolved the issue. 1982 88" 2.25 diesel
1st Jan 2020 10:35pm |
