Home > Puma (Tdci) > Diff Lock Switch and Lamp
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
Me again, I know like a bad penny
So after fitting a new ASHCROFT transfer case with ATB the diff lock lamp on the dashboard only intermittently lit with diff lock engaged and then didn't light at all. The very kind Mr WOLF said check the switch.
So is this the switch ?
(that lights the lamp on the dashboard when diff lock is engaged - I don't have a low range indicator as it says in the manual)
Then Google says that if I short the wires leaving towards the dash the dash lamp should light - is this correct ?
What else ? Erm if I block the rear wheels and jack up the front wheel, the wheel should turn easily, then if I engage diff lock it should not turn at all. Is that right ? I can try that in my lunch hour tomorrow.
If it is the switch I don't suppose anyone knows how to find the part number? its for a 2008 TDCI
I feel embarrassed asking all these questions Embarassed but its the only way I am going to learn and I've got the bug now.
Post #806356 15th Dec 2019 7:23pm
topless_matt
From your picture it looks like the switch is located towards the right hand side You can see the two other green and black wires.
The difflock switch is vertical when looking down onto the top of the box, located to the rear of the diff lock activation linkage.
Very easy to remove, it is a 19mm head which can be done with a spanner or a crows foot wrench.
Disconnect the wiring plug first so as not to twist the wires as you unscrew it from the housing.
Test by closing the switch and check continuity using a multimeter.
I, now in the process of changing mine as I have just had the switch fail on mine.
Post #806377 15th Dec 2019 9:02pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Matt, how did you get to the switch?
I've got to change mine but the thought of lifting the floor out to reach it has made me delay until I have more time
Thanks 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #806379 15th Dec 2019 9:09pm
The difflock switch is in the extreme top right corner of the workshop manual picture, it is not the highlighted switch.
Post #806389 15th Dec 2019 9:32pm
topless_matt
Thanks
You can do it from the centre panel is your fairly dexterous with your hands.
If yours is a tdci then it is helpful to pop the high low linkage off too to get more access.
If you can’t disconnect the two sections of the cable connector, you can pull the pair off the mount and deal with it in the cab.
If you don’t have a crows foot wrench the spanner may be a bit of a wonky angle but you only need to crack the seal.
Doing mine on Wednesday so will take some pics of it helps
Hope that helps
Matt
Post #806392 15th Dec 2019 10:05pm
Rosco
Much appreciated. Pics would be useful 2007 - Stornoway Grey 90 XS SW - Gone
Post #806399 15th Dec 2019 10:59pm
CharlieDonuts
Oh flip. This sounds much harder than I thought. I read somewhere to take the cubby box out which is now half in half out while I try and find another pair of hands.
Post #806404 16th Dec 2019 6:59am
topless_matt
Managed to get it done? It’s not too bad once you get into it. Curious why you need a second set of hands to take out the cubby box? Hold my beer and watch this!
Post #806488 16th Dec 2019 6:05pm
CharlieDonuts
Hello TPM - So I found the switch by feel and the connector is on and going to the loom. I still have to jack it up and check that diff lock is engaging but I can get it to wheel slip driving in circles on gravel so I guess it is. So yeah probably the switch will need to come out.
I have ordered the wrenches from Amazon - Goose Foot Wrench or 'cles pattes d'oie' - in French. Tomorrow I will take the rubber glove off the gear levers and the foam pad out to see if I can get to it but it looks as if the tin wear that makes the gearbox tunnel is going to have to come out. Then the cubby box. I asked in another post about the Cubby Box. The bolts came half out and now are just turning. 'Go Beyond' said that they go into 'Rivnuts' underneath and its these that are turning. So we gotta get mole grips on them below and undo from above.
I am going around my mate Damien house Thursday after work. We will get the Cubby box out. He is quite a good mechanic so he might be able to get the switch out with a normal spanner. He likes working on the Land Rover - keeps muttering ' Censored English' which makes me giggle.
As I understand it. Disconnect the connector. Take the switch out. Reconnect the connector. Turn on the ignition. Press the the button on the switch and if the lamp on the dash does not light the switch is duff.
Its my daily driver. I don't have a garage. My parking is the public parking. They have cameras and guards 24/7 which I like. Fixing stuff mostly happens either around Damiens or by the local fishing pond in the summer or it goes to Francois the Land Rover mechanic who is about 45 minutes away.
Honestly you guys and this forum just about make it possible for me to have a Land Rover
Post #806495 16th Dec 2019 7:11pm
topless_matt
With regard to checking the switch yes you are right how to check it. Or use a multimeter.
If you clamp the bottom of the rivnut from underneath with molegrips to get them out then you don’t need to take the transmission tunnel out.
Once you take the cover plate out of the middle seat box you can actually crimp up the rivnuts in a vice so they work next time.
All easy to do from the top rather than taking out the transmission tunnel, to do that you need to remove the front seats in you have the sound deadening still. Hold my beer and watch this!
Post #806517 16th Dec 2019 8:45pm
topless_matt
Done this afternoon. Total of 20 mins start to finish maximum.
View from the inside of the cab, bad angle mind you
Switch with the wires poking out of the top can see the high low linkage in the way. Press the button in on the side and push off using a prybar
Plug with the linkage removed. Short handled 19mm spanner to undo it.
In typical fashion, refitting is reverse of removal. Laughing
Matt Hold my beer and watch this!
Post #806763 18th Dec 2019 3:28pm
Rosco
Brilliant. Thanks Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
Post #806767 18th Dec 2019 3:50pm
topless_matt
No problem Hold my beer and watch this!
Post #806788 18th Dec 2019 6:11pm
CharlieDonuts
Hi Topless Mat
So last night
We jacked up the front wheel, it spun freely, we engaged the diff lock and the wheel was blocked, we repeated three of four times, it seems to me that the diff lock is engaging as it should - just that the dashboard lamp is out.
We got the cubby box out.
Removed the inspection plate.
We can see the switch.
I have ordered an new one from the UK.
In the meantime I will have a look at the linkage to see how you got that apart !
Charlie
Post #806997 20th Dec 2019 10:54am
topless_matt
With the linkage. There is a small round button that you push in. Then pull or pry the whole plastic connector towards the drivers seat.
In this pic the button is on RHS and pull the unit across to that side. Hold my beer and watch this!
Post #807008 20th Dec 2019 1:54pm
