- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
dorsetsmith
Disconnect the connector. Take the switch out. Reconnect the connector. Turn on the ignition. Press the the button on the switch and if the lamp on the dash does not light the switch is duff.
dash does not light
1. Disconnect the connector. with small wire short out plug on wiring loom Turn on the ignition. will dash diff light illuminate
2. with small wire short black wire with blue tracer on the plug to metal work of the transfer box Turn on the ignition. will dash diff light illuminate
as i have one with same problem but not switch but switch ground open circuit
20th Dec 2019 4:46pm |
