![]() | Home > Maintenance & Modifications > 2010 Puma, brake light fuse blowing |
Have you got a towing socket? If so have a good look at that (including the connections on the back), or easier unplug it and see if it solves the issue.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Sportacourt Member Since: 13 Mar 2014 Location: Marlborough Posts: 9 ![]() ![]() ![]() |
Hi Steve, thanks for the tip, sadly just checked and all ok
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2226 ![]() ![]() ![]() |
pretty sure someone else mentioned a problem where the loom went onto the back door for the 3rd b/light......
Thanks, looked at that as well, all seems ok
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1851 ![]() ![]() ![]() |
Was there something with the 3rd brake light surround chaffing the heating element and causing probs - or was that it just stopped the HRW?
Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91 ![]() ![]() |
The chafing just affects the third brake light. Fix is to run a power lead directly from loom behind the door card.
Doesn't fix OPs problem. |
