Home > Maintenance & Modifications > 2010 Puma, brake light fuse blowing |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2229 |
Have you got a towing socket? If so have a good look at that (including the connections on the back), or easier unplug it and see if it solves the issue.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
9th Dec 2019 2:49pm |
Sportacourt Member Since: 13 Mar 2014 Location: Marlborough Posts: 9 |
Hi Steve, thanks for the tip, sadly just checked and all ok
9th Dec 2019 4:26pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2159 |
pretty sure someone else mentioned a problem where the loom went onto the back door for the 3rd b/light......
9th Dec 2019 4:40pm |
Thanks, looked at that as well, all seems ok
9th Dec 2019 7:34pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
Was there something with the 3rd brake light surround chaffing the heating element and causing probs - or was that it just stopped the HRW?
9th Dec 2019 9:49pm |
Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91 |
The chafing just affects the third brake light. Fix is to run a power lead directly from loom behind the door card.
Doesn't fix OPs problem. |
10th Dec 2019 11:42am |
