![]() | Home > Technical > Fitting Hp24 autobox |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
Hp24? You having the electronics?
Anywho, pumpkin (torque converter) on the pump first, make sure itâs sat properly to avoid damage. All the information you need can be found on Ashcroftâs site, as well as hints and tips, as well as parts for the filter swap etc. I had Ashcroft build me a âmonster boxâ best thing i did as it transformed the v8. |
The Monkey Member Since: 11 Aug 2013 Location: Meath Posts: 63 ![]() ![]() |
Cheers lad! I've a compushift to make it work.
Hopefully đ¤ I'll check out the Ashcroft site. |
