Home > Technical > Clutch or spigot bush issue
Roosterrs
My Discovery 2 makes a whining noise when cold. This is when the clutch is semi engaged and slipping the clutch when reversing off my drive. Doesn't make a noise after this.
Is this the release bearing or the spigot bush? Its a TD5 manual.
Post #804378 1st Dec 2019 10:23pm
Almost certainly the spigot bush. This is a common problem with the Td5.
Post #804383 1st Dec 2019 10:36pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
But if you remove the gearbox to fix it, you can might as well replace the clutch plate, pressure plate and release bearing.
No use doing it now only to do it again later on.
Post #804452 2nd Dec 2019 2:41pm
