![]() | Home > Technical > Clutch or spigot bush issue |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17622 ![]() ![]() ![]() |
Almost certainly the spigot bush. This is a common problem with the Td5.
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
But if you remove the gearbox to fix it, you can might as well replace the clutch plate, pressure plate and release bearing.
No use doing it now only to do it again later on. |
