![]() | Home > Maintenance & Modifications > 4 Pot Caliper Question?? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
They’re different for a reason - the rear brakes are balanced for a lower braking force.
Swim_Cap Member Since: 13 Oct 2019 Location: Cumbria Posts: 17 ![]() ![]() ![]() |
Roger, thank you 🙏
I have 4pots on my 90. Would not advise it, even with a bias valve it is very nervous in the wet! 02' 110 TD5 Double Cab Rebuild Thread
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
My old '84 90 van would lock up its rear brakes when empty - and that was with drums on the back axle!
I fitted them with the intention of using them for fiddle brakes but might end up changing back to 2-pot calipers.
Even with the weight of Blacksheep x-member, chassis reinforcement, full cage and the spare in the load bed of the truck cab, it is just too light at the back. ![]() Click image to enlarge Steve 02' 110 TD5 Double Cab Rebuild Thread |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 563 ![]() ![]() ![]() |
You can fit 02 onwards Defender 110 rear calipers and discs, they are just slightly larger.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4799 ![]() ![]() ![]() |
I have a 110 brake setup on my 90. Really good stopping power but still well balanced
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
George - what's the difference between the 90 and 110 set up - and how ease is it to upgrade ?
I have never been happy with my 90s brakes and almost rear ended a car in Knowle today ![]() |
Firstly, check your brake servo! Mine was cracked and leaking atmosphere into the vaccum.
Easy bolt on swap, vented fronts are the same between 90 and 110. Rear 110 discs are larger diameter and the calipers have bigger pistons ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
ref fiddles, I ran 110 rear calipers, twin pot as stud, with inline fiddles, worked well. in fact front locker and fiddles and it went alot of places.
or use two sets of calipers on rear, one for fiddles on on std system Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
joejohnson_19 Member Since: 19 Oct 2024 Location: Cambridge Posts: 1 ![]() ![]() |
Got any photos of they this have been mounted |
