Home > Maintenance & Modifications > Eberspacher fuel pick up
Page 2 of 2 <12
sako243
Swirl pot, that's what he used. Was just having a brain fart on the name. Just a cheap one off ebay. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #803916 28th Nov 2019 8:38am
sako243
jst wrote:
Swirl pot or catch can is a good idea. As is running them off aux tanks or botton of through flow additional tanks. On tick over once up to temp the fuel consumption is pretty minimal on webastos
The reason John went swirl pot off the main tank was that I think on a previous setup he had a diesel heater but all his vehicles are V8s and kept forgetting to fill up the separate tank which meant it usually ran out at the most inopportune time. With the 129 I think he managed to source a petrol heater which meant that by plumbing it in the way I described meant he never had to remember to fill it up and never ran the vehicle out of fuel.
If they did run out of fuel while camping they could just switch on the engine to refill it but then it was a conscious decision and you knew how much fuel was in the tank at the time. The very minor downside being that you could end up with a couple of litres in the swirl pot but since it was easy to empty by going under the vehicle. Mind you with a 4.6 V8 2l won't get you far Laughing Ed
Post #803955 28th Nov 2019 2:23pm
Page 2 of 2 <12
