- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
sako243
jst wrote:Swirl pot or catch can is a good idea. As is running them off aux tanks or botton of through flow additional tanks. On tick over once up to temp the fuel consumption is pretty minimal on webastos
The reason John went swirl pot off the main tank was that I think on a previous setup he had a diesel heater but all his vehicles are V8s and kept forgetting to fill up the separate tank which meant it usually ran out at the most inopportune time. With the 129 I think he managed to source a petrol heater which meant that by plumbing it in the way I described meant he never had to remember to fill it up and never ran the vehicle out of fuel.
If they did run out of fuel while camping they could just switch on the engine to refill it but then it was a conscious decision and you knew how much fuel was in the tank at the time. The very minor downside being that you could end up with a couple of litres in the swirl pot but since it was easy to empty by going under the vehicle. Mind you with a 4.6 V8 2l won't get you far Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
28th Nov 2019 2:23pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
