Home > Puma (Tdci) > Unknown plug/sensor |
vinny Member Since: 30 Oct 2011 Location: Dundalk Posts: 9 |
Can anyone identify this plug sensor beneath the turbo on my 2007 2.4 tdci? It’s not connected to anything I’ve searched on microcat but can’t identify what it’s for or if it should be connected!
19th Nov 2019 2:34pm |
Cool thanks for clarifying 👍 Next question , what oil should I put in the engine ...😆 Just kidding
I’ve the engine on the floor and have replaced the clutch, rear crank seal, vacuum pump, egr valve and currently replacing the injector seals and the seals where the injector pass thru the rocker cover. I’ve read the posts on the timing chain and how it’s not as robust as the td5. I’m leaning towards a kit with the sprockets and new cover. My question is are there brands to avoid or is there a generally accepted good supplier? paddocks and Craddock are expensive compared to transit parts uk |
19th Nov 2019 7:06pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2429 |
Any idea whats this plug? It is located under the intake manifold
Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
15th Oct 2022 11:30pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 823 |
possibly the EGR? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
17th Oct 2022 12:26pm |
I was told it is the throttle body. And it is a pig to fit and remove Puma 110" SW
17th Oct 2022 2:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17458 |
There is no "throttle body" on a TDCi (nor TD5 for that matter).
17th Oct 2022 3:58pm |
Throttle then Puma 110" SW
17th Oct 2022 4:01pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Yes there is, on a 2.2. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
17th Oct 2022 4:50pm |
Ah, didn't know that, happy to be corrected! There isn't on a 2.4.
17th Oct 2022 5:07pm |
