![]() | Home > Technical > 200tdi front stub axles |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8181 ![]() ![]() ![]() |
Pressing the bronze Bush onto the stub you mean and now on assembly the cv doesn't stick out of the stub far enough?
If so take stub off, reseat shaft/cv and go again Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
mark23 Member Since: 14 Feb 2018 Location: EXMOUTH Posts: 5 ![]() ![]() ![]() |
Hi
Thanks for the info I guess its a really tight fit. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2712 ![]() ![]() |
I’ve had this with poor quality aftermarket bronze bushes, the CV doesn’t fit into them properly once they’re fitted into the stub axle.
Hi
Thanks for the info now all sorted. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17622 ![]() ![]() ![]() |
Normal engineering practice with bushes of this type is to reamer them to size after fitting, but this shouldn't be necessary in this application.
Hi
What I found strange was when removing the old bush from the old stub axle it then didn't fit the cv shaft it was originally fitted to. |
