Home > Technical > Brake Fluid Consumption
OsloBlue
All, Hand brake/ warning light came on Saturday when going downhill / Braking.
Topped up My brake Fluid this morning and all ok.
Problem is it went from 100% to 40% in about three months. (say 800 miles)
I'm currently driving around with a broken ABS, and semi worn rear pads.
Is this sort of consumption normal or to be expected given my circumstances? I'm on IG: https://www.instagram.com/osloblue42/
Post #799758 28th Oct 2019 9:14am
Mdm
i would park it up as you have a leak or split pipe.
not safe to drive it for sure.
broken abs does not mean fluid loss normally,
nor does worn pads to the extent you describe.
Post #799764 28th Oct 2019 9:47am
OsloBlue
MDM, i still get back pressure from my brake pedal,
Will check Servo / slave cylinder when i have a chance. I'm on IG: https://www.instagram.com/osloblue42/
Post #799765 28th Oct 2019 9:55am
Mdm
you may well have a pedal but you are leaking fluid.most likely a rusty brake pipe ? or the 2 things you have mentioned.
defo time for a workshop visit
Post #799766 28th Oct 2019 10:00am
OsloBlue
Yeah need to book it in with my techie as MoT is coming Soon and will fail with ABS situation I'm on IG: https://www.instagram.com/osloblue42/
Post #799767 28th Oct 2019 10:02am
90 Dreamer
in basic terms when all components are new the fluid should be at the upper level in the resevoir then its sized so that as the discs / pads wear to their minimum it will drop to its lowest level - you should never have to add fluid between times
Post #799774 28th Oct 2019 10:28am
Huttopia
Spot on- I had a leak on the P38 which I initially thought was a sensor problem, but no it was a cracked pipe and leak. It still all seemed to function ok, but best sorted asap.
Post #799776 28th Oct 2019 10:54am
As other have said, if you're using ANY brake fluid you need to investigate urgently. You should never lose a drop, and any loss is indicative of a serious defect.
Post #799777 28th Oct 2019 11:00am
OsloBlue
Ah so it could be that my rear pads have finally worn.
Still worth Mentioning it to my tech and hopefully get it checked by a professional.
Last thing i want to do is rear-end someone trying to brake.
Edit: looks like i'm taking a four hour train journey Wednesday. I'm on IG: https://www.instagram.com/osloblue42/
Post #799778 28th Oct 2019 11:00am
OsloBlue
Also going to check the level when i get home.
Its actually a good thing that there is a sensor that can tell you as to what level your brake fluid is at. I'm on IG: https://www.instagram.com/osloblue42/
Post #799781 28th Oct 2019 11:07am
jst
were pads new at 100% fill?
when you say only 40% left how do you know that? do houmeanin the whole system or the res,? guess or measured? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #799788 28th Oct 2019 2:04pm
OsloBlue
Break fluid reservoir at 40%
Rear pads were wrong old type that were thinner than the ones required for 2a
rear pads after visual inspection last month I'm on IG: https://www.instagram.com/osloblue42/
Post #799789 28th Oct 2019 2:15pm
