![]() | Home > Technical > Brake Fluid Consumption |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
All, Hand brake/ warning light came on Saturday when going downhill / Braking.
Topped up My brake Fluid this morning and all ok. Problem is it went from 100% to 40% in about three months. (say 800 miles) I'm currently driving around with a broken ABS, and semi worn rear pads. Is this sort of consumption normal or to be expected given my circumstances? I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
MDM, i still get back pressure from my brake pedal,
Will check Servo / slave cylinder when i have a chance. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1636 ![]() ![]() |
you may well have a pedal but you are leaking fluid.most likely a rusty brake pipe ? or the 2 things you have mentioned.
defo time for a workshop visit |
Yeah need to book it in with my techie as MoT is coming Soon and will fail with ABS situation I'm on IG: https://www.instagram.com/osloblue42/
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2188 ![]() ![]() ![]() |
in basic terms when all components are new the fluid should be at the upper level in the resevoir then its sized so that as the discs / pads wear to their minimum it will drop to its lowest level - you should never have to add fluid between times
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Spot on- I had a leak on the P38 which I initially thought was a sensor problem, but no it was a cracked pipe and leak. It still all seemed to function ok, but best sorted asap. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
As other have said, if you're using ANY brake fluid you need to investigate urgently. You should never lose a drop, and any loss is indicative of a serious defect.
Ah so it could be that my rear pads have finally worn. Still worth Mentioning it to my tech and hopefully get it checked by a professional. Last thing i want to do is rear-end someone trying to brake. Edit: looks like i'm taking a four hour train journey Wednesday. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Also going to check the level when i get home.
Its actually a good thing that there is a sensor that can tell you as to what level your brake fluid is at. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
were pads new at 100% fill?
when you say only 40% left how do you know that? do houmeanin the whole system or the res,? guess or measured? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Break fluid reservoir at 40%
Rear pads were wrong old type that were thinner than the ones required for 2a rear pads after visual inspection last month I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
