![]() | Home > Technical > Steering wheel freeplay |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
Too common, but can almost certainly be adjusted out with the adjustment on the box. Simple procedure. You will have become gradually used to the wear as it come on very slowly, once adjusted you will be amazed how crisp it feels again!. 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
there is a specified limit detailed in the factory manual. From sepia tinted memory it is 6mm either side of centre at the rim of the steering wheel. Or is it 6mm free play in total? Cannot remember and manual is 800 miles away at the moment It is not a Defender, it is a One_Ten
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 ![]() ![]() ![]() |
Check your drop arm ball joint. That’s the usual culprit for this play. Easy job to change with a repair kit available from most places. Other thing to check is the ujs on the steering column in the engine bay as these can wear if it’s an older defender.
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
While you're checking the drop arm, also check the arm is seated on the steering box splines and the nut is still tight (176 Nm) especially if the drop arm or box has been replaced at some point. Don't ask how i know this
You found out the hard way too then
geostrategist Member Since: 25 Apr 2019 Location: UK Posts: 60 ![]() ![]() ![]() |
So how do I do that then? |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1234 ![]() ![]() ![]() |
I'd check all the other links in the steering (there are a lot) before you start fiddling with the steering box. I had that and thought it was but turned out to be the UJs in the steering column instead. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Silvertoolbox Member Since: 13 Oct 2018 Location: Westhill Posts: 43 ![]() ![]() |
It used to be 3" each way at rim for a steering box and about 1/2" for rack and pinion for the MOT..
Mind you, at the limit not much fun trying to go in a straight line. Needs looking at. Free play in box needs adjusting when straight ahead when tightest. Ex scottish & southern 110 Td5 van (shed) with PTO driven winch (L-R special vehicles) Before that, Disco 1, Freelander 1, 26105382 80" with a 1600cc (not much slower) |
