Home > Puma (Tdci) > Optima battery still reasonable choice?
toetankh
Netherlands 2007 Defender 110 Puma 2.4 SW Stornoway Grey
I'm looking into replacing my 55Ah Yellowtop with a 75Ah version. Because it will be linked to my existing 55Ah Yellowtop starter battery (like to keep batteries similar due to dual-battery setup).
Is the 75Ah Yellowtop still a reasonable choice (pretty old design already), or should I be looking into different options?
Not interested in LiFePo, because of price and cold weather charging limitations.
Thanks!
Sven
Post #798275 15th Oct 2019 12:16pm
jst
connected with VSR? if not and in parallel one will drain to the other as different sizes.
For the money, if your keen to spend that much North Star or Odyssey would be my preference based on my experience. Having said that you wont go far wrong with Numax. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #798283 15th Oct 2019 12:43pm
toetankh
jst,
Jup, via VSR. I'll have a look at your suggestions!
Post #798297 15th Oct 2019 1:40pm
bankz5152
Not sure why people like Optimas so much. Very expensive with a generally lower aH than others with similar if not lower CCA Instagram @defender_ventures
Empire Tuning - Agent
Post #798322 15th Oct 2019 5:27pm
