![]() | Home > Expedition & Overland > Charging Camping Battery |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
I have a couple of spare car batteries that I use when camping for charging phones, lights etc is it possible to charge these from the cigarette lighter socket or is there some gizmo available that does?
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
search split charge system if you want a system, but be awaire this is a subject that people have lots of different opinions on, cheap and chearfull, do it yourself with a relay and intelegent systems,
i personally have no idea ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
Put a 12V socket directly onto the battery, then charge it from 220V powerpoint --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
You need to buy a decent 12v-12v battery charger. Do a Google search or pop down to your favourite 4x4/outdoor shop - there are plenty to choose from (that plug into your cig socket).
Depending on what type of battery you're charging (normal car battery, OR a deep cycle battey) will determine the quality of such charger. The cheap ones are probably ok for normal batteries, but you'd need quite a specialised one for the deep cycle batteries, and then wouldn't achieve much more than a 65% charge anyway. They're also rather slow when charging deep cycle batteries so you'd need to be driving around for a good 6 or 7 hours at least. www.ralton.co.za |
