Home > Expedition & Overland > Charging Camping Battery |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
I have a couple of spare car batteries that I use when camping for charging phones, lights etc is it possible to charge these from the cigarette lighter socket or is there some gizmo available that does?
10th Jun 2011 3:34pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
search split charge system if you want a system, but be awaire this is a subject that people have lots of different opinions on, cheap and chearfull, do it yourself with a relay and intelegent systems,
i personally have no idea |
22nd Jun 2011 11:18am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
Put a 12V socket directly onto the battery, then charge it from 220V powerpoint --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
22nd Jun 2011 12:24pm |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
You need to buy a decent 12v-12v battery charger. Do a Google search or pop down to your favourite 4x4/outdoor shop - there are plenty to choose from (that plug into your cig socket).
Depending on what type of battery you're charging (normal car battery, OR a deep cycle battey) will determine the quality of such charger. The cheap ones are probably ok for normal batteries, but you'd need quite a specialised one for the deep cycle batteries, and then wouldn't achieve much more than a 65% charge anyway. They're also rather slow when charging deep cycle batteries so you'd need to be driving around for a good 6 or 7 hours at least. www.ralton.co.za |
23rd Jun 2011 11:55am |
