Home > Td5 > Can I use a Discovery Gearbox in my Defender?
bigfatsi
United Kingdom 2003 Defender 110 Td5 CSW Aintree Green
Hi,
I've got a feeling that the gearbox on my daily needs a rebuild. It's a 2003 TD5 110CSW.
Don't have time to wait whilst it's sorted, so considering grabbing an R380 out of a Disco as they seem plentiful and cheap. Then I've got time to get the box 'fixed'.
I know the transfer box ratios are different between Disco & Defender and I presume there's a certain amount of ancillary swapping required, but are the internals and ratios the same?
TIA
S
Post #796630 4th Oct 2019 7:27am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I think the input shaft has a differnt length so it will probably a lot off work to get that in. But somebody with more knowledge will tell you exact. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #796633 4th Oct 2019 7:32am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
You have to strip the box the change the selector shafts as they are different between Defender and Discovery’s.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #796634 4th Oct 2019 7:33am
bigfatsi
Ah. That seems like a royal pain. Thanks for the quick replies.
S
Post #796644 4th Oct 2019 9:15am
rallysteve
You dont have to strip the box. Ashcroft make a selector adaptor that allows fitment of the defender shifter to the discovery box. Used one in my V8 to fit a defender LT77 selector housing to a discovery R380.
https://www.ashcroft-transmissions.co.uk/d...-yolk.html
Post #796647 4th Oct 2019 9:30am
Mo Murphy
Why not just give your vehicle to Ashcroft for the day and have them fit a an exchange recon unit.
It's a lot less trouble than faffing around with disco boxes.
50 Shades of Pennine Grey
Post #796654 4th Oct 2019 10:48am
bigfatsi
Ashcroft would be great if A) They weren't so far away and B) I wasn't skint. lol
S
Post #796657 4th Oct 2019 10:53am
