Home > Wheels & Tyres > Cooper Tyre height 265/70-R16
Dutch G4
Netherlands
Searching for 5 new tyres for my 110 station, Cooper ST Maxx 265/75-R16 but i can't find them in Holland or Belgium, no company has them in stock at the moment. Size 265/70-R16 is available, i have searched in all topics on the forum and i know now that the speedo will not be accurate anymore (i don't mind) but can i expect other problems with a tyre height 70 ?
Size 285/75-16 is available and also 235/75-16 but the 265's are just right for me ........
Thx for your help, Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
Post #796496 3rd Oct 2019 7:41am
hank
Negligible difference. 13mm difference in sidewall
265-70-16 has a 198mm sidewall. 803mm overall diameter
265-75-16 has a 185mm sidewall. 777mm overall diameter
You can compare further at https://tiresize.com/tyre-size-calculator/ > 110 XS Double Cab
Post #796507 3rd Oct 2019 8:55am
JOW240725
I think I've been beaten to it now but...
Personally I think 265/70R16 will look too small on a 110. If you really can't find 265/75R16 then I would stick with 235/85R16 which has the same diameter. James
Instagram @suffolk_rovers
Post #796509 3rd Oct 2019 9:00am
90 Dreamer
remember that the sidewall "height" is a % of the width and not an actual measurement so comparing different width tyres with the same aspect ratio are totally different
Post #796514 3rd Oct 2019 9:24am
Dutch G4
Netherlands
[/quote]You can compare further at https://tiresize.com/tyre-size-calculator/[/i][quote] handy tool, thx.
The 'problem' is that i have been reading / searching / comparing tyres for 2 weeks now and had finally decided to go for the Coopers because the reviews & looks are ok but now they are not available Crying or Very sad
I found below 2 pics, my choice was also based on these ...... it was between the STT's or the ST Maxx
I think i will go for the Cooper STT Pro now, these are available in 265/75-16 and i like them very much on a 110; Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
Post #796519 3rd Oct 2019 9:39am
JOW240725
I'm in the same position. I was all set for the STT Pros until I discovered they were only rate at 68mph Shocked Now I don't know. Confused
 James
Post #796543 3rd Oct 2019 12:34pm
Dutch G4
Netherlands
68mph each tyre x4 ........ Very Happy
then the STT's are no option for me; on my TD5 G4 i had Hankook Dynapro MT tyres in 285/75-16, very good also in rain and
not too much noise at higher speed..... will probably take these again or BFG, the search will continue Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
Post #796544 3rd Oct 2019 12:54pm
Dutch G4
Netherlands
Hankook Dynapro MT
Post #796547 3rd Oct 2019 1:06pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
I used to run the maxx’s on my 90, a nice tyre by all accounts - though they did replace simmex extreme’s which were far too overkill for me. I’d be torn between the STT’s and Maxx’s come replacement time for my BF AT’s. Don’t envy your decision!!
Post #797206 8th Oct 2019 12:12am
Dutch G4
Netherlands
Decision is made: Cooper STT Pro 265/75-16 on Modulars ..... wheels are in the paintshop at the moment and will be painted Keswick green, like the 110. Will post pics as soon as they are fitted. Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
Post #797262 8th Oct 2019 1:45pm
G4V JW
Good choice, the 110 above looks immense on the colour coded modulars !!! Instagram; @gavin_walding
Post #799208 23rd Oct 2019 6:10pm
camelman
Given that many of the above tyres are only 68mph rated, driving at 70mph on the motorway therefore leaves you on a sticky wicket from an insurance perspective does it not???
Post #799212 23rd Oct 2019 6:30pm
Dutch G4
Netherlands
Wheels at the paintshop
Post #799317 24th Oct 2019 1:59pm
Why are they being painted with the valve stems in situ?
Post #799322 24th Oct 2019 2:23pm
Dutch G4
Netherlands
it was impossible to get them out so we decided to cover them with tape Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
Post #799325 24th Oct 2019 2:28pm
