![]() | Home > Wheels & Tyres > Cooper Tyre height 265/70-R16 |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
Negligible difference. 13mm difference in sidewall
265-70-16 has a 198mm sidewall. 803mm overall diameter 265-75-16 has a 185mm sidewall. 777mm overall diameter You can compare further at https://tiresize.com/tyre-size-calculator/ > 110 XS Double Cab |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
I think I've been beaten to it now but...
![]() Click image to enlarge Personally I think 265/70R16 will look too small on a 110. If you really can't find 265/75R16 then I would stick with 235/85R16 which has the same diameter. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2191 ![]() ![]() ![]() |
remember that the sidewall "height" is a % of the width and not an actual measurement so comparing different width tyres with the same aspect ratio are totally different
Dutch G4 Member Since: 29 Jan 2015 Location: near Rotterdam Posts: 49 ![]() ![]() |
[/quote]You can compare further at https://tiresize.com/tyre-size-calculator/[/i][quote] handy tool, thx.
The 'problem' is that i have been reading / searching / comparing tyres for 2 weeks now and had finally decided to go for the Coopers because the reviews & looks are ok but now they are not available ![]() I found below 2 pics, my choice was also based on these ...... it was between the STT's or the ST Maxx ![]() Click image to enlarge ![]() Click image to enlarge I think i will go for the Cooper STT Pro now, these are available in 265/75-16 and i like them very much on a 110; Duct tape is The Force; is has a light side, a dark side and it holds the universe together. |
I'm in the same position. I was all set for the STT Pros until I discovered they were only rate at 68mph
![]() ![]() ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
68mph each tyre x4 ........
![]() then the STT's are no option for me; on my TD5 G4 i had Hankook Dynapro MT tyres in 285/75-16, very good also in rain and not too much noise at higher speed..... will probably take these again or BFG, the search will continue Duct tape is The Force; is has a light side, a dark side and it holds the universe together. |
Hankook Dynapro MT
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Duct tape is The Force; is has a light side, a dark side and it holds the universe together. |
zippo87 Member Since: 29 Mar 2019 Location: Moray Posts: 100 ![]() ![]() ![]() |
I used to run the maxx’s on my 90, a nice tyre by all accounts - though they did replace simmex extreme’s which were far too overkill for me. I’d be torn between the STT’s and Maxx’s come replacement time for my BF AT’s. Don’t envy your decision!!
Decision is made: Cooper STT Pro 265/75-16 on Modulars ..... wheels are in the paintshop at the moment and will be painted Keswick green, like the 110. Will post pics as soon as they are fitted. Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 ![]() ![]() |
Good choice, the 110 above looks immense on the colour coded modulars !!! Instagram; @gavin_walding
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3387 ![]() ![]() |
Given that many of the above tyres are only 68mph rated, driving at 70mph on the motorway therefore leaves you on a sticky wicket from an insurance perspective does it not???
Wheels at the paintshop
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
Why are they being painted with the valve stems in situ?
it was impossible to get them out so we decided to cover them with tape Duct tape is The Force; is has a light side, a dark side and it holds the universe together.
