Home > Puma (Tdci) > Sleeping in a TDCi! |
flinty99 Member Since: 28 Jun 2010 Location: Durham Posts: 41 |
Somebody should have asked. I had my Jetboil.
8th Jun 2011 9:32pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
That's what I'm looking for thanks for that. I have a simple Trangia to warm water and cook with but this allows you to stay in the vehicle if the weather isn't great and it's a lot simpler but slower.
I presume the 12V connection comes from the plug which I have just used to plug the tow bar electrics into (back of rear light!) Can you connect it from anywhere else in the back or buy some sort of double plug adaptor? Noworries 1000 Watt thing sounds a bit pricey and professional for me just making a cuppa! |
9th Jun 2011 6:45am |
As has been covered before there's a spare power feed behind the right rear speaker housing hence it being a popular place to add a power socket. Next question? Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
9th Jun 2011 8:41am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
As MOG says there are two wires behing the speaker panel with a perm live and earth - they are usually taped to the side of the loom and totally seperate to the towing electrics.
You can either remover the panel completely or just the speaker. I removed the panel completely to drill a hole for the socket. Click image to enlarge Click image to enlarge John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
9th Jun 2011 10:21am |
^^Pretty much where I put mine too
Forgive all the dog & horse hairs and spatters of mud over the door and general non pristine appearance Zag Here's a photo of where I put the rear worklamp switch too - just in case you wake up in the night with an urgent need to know Click image to enlarge Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
9th Jun 2011 10:50am |
Thanks for that, Are there particular sockets to get or am I just looking for a 12V socket from Halfords?
Somthing like this maybe with a 20 amp limit http://www.devon4x4.com/index.php?page=sho...;Itemid=14 So I presume there is a spare wire behind each rear speaker as a rear light would be handy Last edited by Zagato on 9th Jun 2011 12:16pm. Edited 1 time in total |
9th Jun 2011 11:52am |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
Uh oh - this is stirring rather inconvenient (while we have a young baby) camping urges... Defender 110XS SW gone... now VW California 180 4 Motion.
9th Jun 2011 12:04pm |
Now we are talking
http://www.the12voltshop.co.uk/Shop/applia...d-24-volt/ |
9th Jun 2011 12:21pm |
Mine are just 12v cigarette lighter style sockets, Vehicle Wiring Products or similar will be able to supply everything you need. http://www.vehicle-wiring-products.eu/VWP-...mepage.php http://www.vehicle-wiring-products.eu/VWP-...12vacc.php Don't forget we are talking Land Rover, one spare power outlet behind one speaker panel is deemed quite enough! Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
From memory there is only power on the one side. I have used the 12v marine grade sockets from MSS and Mudstuff before which are standard 'fag lighter' types - I would steer clear of any cheap options. This time I fitted a Hella type socket as they have a 'tighter' connection and I have a number of items with a Hella plug fitted. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
9th Jun 2011 12:28pm |
Just spoken to Devon 4x4 who said I need to find out what amp-age the existing Defender wire is capable of and suggests it would be a good idea to put a fuse in somewhere or better run a thick wire from the battery with a fuse in it
I'm probably only ever going to use it for a mobile light and a kettle rated at 14 amps max Mudstuff also don't know what the Defender wires are rated at and suggest finding out before plugging in a 14 amp kettle in. ANYONE know |
9th Jun 2011 12:34pm |
The spare feed is constantly live and fused, I blew mine and it's one of the fuses in the drivers seatbox. If you are going to run high draw items off the socket then yes I would run a new, fused cable direct from the battery. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
9th Jun 2011 1:04pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
Isn't having a 12v kettle not 'camping' ?
I like the dual fuel Coleman stoves! |
9th Jun 2011 1:14pm |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
I have the twin burner Coleman and it will boil a litre of water in about 2 minutes, i bet those kettles take an age. |
9th Jun 2011 2:26pm |
