Home > Maintenance & Modifications > Scheelmann Sportline LR edition - HELP!!!!!
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Hi Gents
i would like to know if somebody was able to install the Scheelmann sportline LR edition seat (driverside) in a defender 90 with the smaller mid seat standard landr rover existing. ( i have a configuration of the 3 stdandard front seats - no console - cubby in the middle)
Most of the images i see shows mostly seats are fitted and in the middle there is a console or cubby
Has anybody fitted the seat with a Mid seat in the middle ??
thanx alot for your help Happy Travel
www.thegippo.wordpress.com
Post #794163 20th Sep 2019 11:59am
JOW240725
I'm sure someone will be along shortly with the answer, but in the meantime have you tried doing a search on here for Scheelmann?
You could try calling 4x4Overlander who supply them, Brendan may be able to help? James
Instagram @suffolk_rovers
Post #794166 20th Sep 2019 12:22pm
sherifsalem
Thanx James for your orientation guess i should try Brendan Happy Travel
Post #794174 20th Sep 2019 1:46pm
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
Have you measured your current seats and set up?
The LR Sportline editions are listed as base width 520mm, max backrest width 510mm
I would think the measurements of your current set up compared to these would mabe give you an answer.
I do have contact detais of one of the Technial engineers there. He was at the LRO Show.
If you would like the details please drop me a PM 110XS CSW TD5.
Post #794179 20th Sep 2019 2:27pm
sherifsalem
I am attaching 3 photos with measures and they point out that the full width of the Mid seat is 350mm and probably a gap of 5mm from each side to each side seat making the total from seat to seat is 400mm but just the width of the mid seat is 350mm.
does anybody with 2 scheelmann seats have a gap of 350mm between his 2 seats
 Happy Travel
Post #794279 20th Sep 2019 10:57pm
