![]() | Home > Maintenance & Modifications > Scheelmann Sportline LR edition - HELP!!!!! |
sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96 ![]() ![]() ![]() |
Hi Gents
i would like to know if somebody was able to install the Scheelmann sportline LR edition seat (driverside) in a defender 90 with the smaller mid seat standard landr rover existing. ( i have a configuration of the 3 stdandard front seats - no console - cubby in the middle) Most of the images i see shows mostly seats are fitted and in the middle there is a console or cubby Has anybody fitted the seat with a Mid seat in the middle ?? thanx alot for your help Happy Travel www.thegippo.wordpress.com |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
I'm sure someone will be along shortly with the answer, but in the meantime have you tried doing a search on here for Scheelmann?
You could try calling 4x4Overlander who supply them, Brendan may be able to help? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thanx James for your orientation guess i should try Brendan Happy Travel
I am attaching 3 photos with measures and they point out that the full width of the Mid seat is 350mm and probably a gap of 5mm from each side to each side seat making the total from seat to seat is 400mm but just the width of the mid seat is 350mm.
does anybody with 2 scheelmann seats have a gap of 350mm between his 2 seats ![]() ![]() ![]() www.thegippo.wordpress.com |
