Home > Technical > Which Voltage Sensing Relay
Page 2 of 2 <12
You can always stick in a diode over the coil too, to suppress voltage spikes and EMI.
The problem happens when the switch drops out with voltage contained in the coil.
It can tend to fly back up the switching positive feed.
Many smaller relays have them in-built.
HD relays rarely do, but you can fit externally easily enough anyway and the coils on these are typically about only about 300mA.
For the instance of the OP’s purpose a Durite VSR would be fine.
We all do things differently, but the voltage drop on cranking is something to bear in mind.
If it kicks in once alternator charging voltage is achieved that’s ideal.
But voltage can vary even due to ambient temp and VSR’s can vary on their switching voltages. That can vary for lots of reasons. WeWillWin🇬🇧🇺🇸
Post #792847 13th Sep 2019 6:02pm
sako243
Bear in mind that the diode across the coil will only suppress fly-back voltages on the circuit activating the relay. Not any fly-back generated from the contactor suddenly disconnecting any load.
You'll also need a diode rated for >~5W (at least a peak rating) given P=VI=14*0.3=4.2W. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #792854 13th Sep 2019 6:22pm
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #792891 13th Sep 2019 8:11pm
landy andy
I’ve fitted Durite VSR to three Land Rovers now, and never had an issue with them. Very simple to install and require not maintenance or operation.
Joins batteries at 13.3v
Disconnects at 12.6v
They also have a 5 second delay in operation so won’t keep flicking on and off.
If, which I never have, needed to jump start myself I would just join my batteries physically as they are next to each other.
https://www.simplysplitcharge.co.uk/0-727-...-charge-vw
Post #792965 14th Sep 2019 8:06am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
why not get a battery to battery charger like those offered by Ctek. Much better IMO due to the charging profiles offered by Ctek, which enables the battery to be fully charged correctly. Leisure batteries don't charge that well from the alternator.
Post #792987 14th Sep 2019 10:25am
Gilloverland
Bit of a price difference though !
Post #793014 14th Sep 2019 2:27pm
windy81
Its a proper job though, and you can add solar or whatever if need be
Post #793027 14th Sep 2019 4:39pm
Page 2 of 2 <12
