Home > Maintenance & Modifications > Who has the Gwyn Lewis front mudflap kit? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3657 |
Should add, it’s the front mud flap kit.
31st Aug 2019 11:57am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1748 |
Me !
Click image to enlarge |
31st Aug 2019 12:34pm |
Cheers Romadog
31st Aug 2019 12:46pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1841 |
Me too - any particular questions, or did Romadog's picture sort it out? Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
31st Aug 2019 12:48pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Me too. They are great although I was a bit reluctant to cut a strip off the wheel arch. I felt this should have been in the description on the website. Still, I’m glad I fitted them. I fitted offset wheels and the corrosion in just one winter inside the rear doors was awful. Fitted these and problem solved 2002 110 td5
31st Aug 2019 1:07pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
Got them at both ends, far better than the Land Rover offering, especially when used in conjunction with the plastic flaps which protect the footwells and the rear cross member.
All fittings and fasteners are either stainless or galvanised. A well thought out piece of kit. The rear flaps mounting system is far more robust then the LR system and the flaps are QD. Click image to enlarge Click image to enlarge It is not a Defender, it is a One_Ten |
31st Aug 2019 1:26pm |
Excellent, much appreciated. Will get them fitted once the rain stops!
31st Aug 2019 1:39pm |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
Me too, saves all of the crap going up the doors. Jeff
1st Sep 2019 4:24pm |
Done. Pleased with them all and simple enough to do.
Click image to enlarge Click image to enlarge |
1st Sep 2019 4:54pm |
All you need now is the matching set for the back. If anything they are even better thought out. It is not a Defender, it is a One_Ten
1st Sep 2019 6:04pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6084 |
Call me dumb.... but I thought the GW flaps were supposed to stop the spray up the side of the vehicles? |
1st Sep 2019 6:59pm |
The spray was there before the mud flaps were moved!!
1st Sep 2019 7:04pm |
[quote="diesel_jim"]
Mudflap extenders are the perfect answer to that. That means as long as you don’t run wider than 235 tires. Eric Standard Click image to enlarge Extended Click image to enlarge Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
1st Sep 2019 7:09pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17281 |
The GL product is great but can give problems if you run larger tyres (eg 255/85 X 16) and want to fit tyre chains.
Ericvv, can I ask who supplies those? |
1st Sep 2019 7:22pm |
