Home > Wheels & Tyres > Spare wheel carrier bolts?
Green Machine
Could anyone tell me the size of the six bolts that hold the spare wheel carrier to the back door? I've just had the carrier blasted and re-sprayed, but the bolts are rusted so would like to replace them to tidy the job up. Presumably stainless wouldn't be a good idea here due to the load?
Thanks,
Tris.
Post #74356 5th Jun 2011 8:51pm
K9F
16MM X 1.5MM thread I believe. Have a look here and give them a call, they can give you all the information and probably the studs you require. I bought the stainless nuts and the quality was and still is after two harsh Winters superb.
http://www.wrington.co.uk/landrover.htm
Edit after re-reading....
Misread your post sorry....above is not what you were after....Nevertheless if you are going to replace, stainless would be my choice as if your carrier has been repainted there would be no issue about dissimilar metal crorosion. Take one of the existing bolts to a marine chandlers (if convenient for you) and undoubtedly they'll have something suitable! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #74414 6th Jun 2011 9:33am
Green Machine
Cheers K9F. I will just have to take one of them out and measure it. I was being lazy and hoping someone could tell me what they are without me doing anything, but it's easy enough just to check! Thanks anyway.
Post #74518 6th Jun 2011 8:24pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Prob M8x30mm at a guess. they have really big (around 60mm Dia.) washers on the back which are a pain to get hold of too. You may have to get them from dealer, or get a local engineer to turn a few, from a bar of stainless.
Post #74555 6th Jun 2011 10:18pm
