Home > Tdi > Engine lifting chains |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1231 |
Piece of rope or chain
Never had an issue with doing it that way, just take it slowly and stop if things start going wrong. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
25th Aug 2019 1:46pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1654 |
If you’re scrapping the disco cut the top slam panel out and lift the engine gearbox and transfer out as one. I’d buy some shackles maybe. Don’t get the crane/pump handle stuck against the bumper
the closer to get the hook to the engine the better as you’ve got to go quite high to clear the front on land rovers and they have a deep enough sump. Thing to remember about an engine crane is it lifts in an arc not straight up. Ratchet strap can be handy to pull the thing level. Click image to enlarge If you’ve not a lot of experience take your time and be safe. Level, flat and smooth surface for the wheels makes life easy. I prefer a forklift you don’t have to fight the arc Click image to enlarge |
25th Aug 2019 3:41pm |
jimmythomson Member Since: 18 Jul 2017 Location: Norfolk, UK Posts: 46 |
Thanks guys I think I'm going to get the angle grinder on it tomorrow and clear some room to get the rear lifting eye in. I might also take off the front section to avoid having to lift over it.
Will invest in a 2 leg lifting chain kit too. I'll report back soon Jimmy. |
25th Aug 2019 4:01pm |
I managed to get my hands round the back and attach the proper rear lifting eye in the end. It was a real pain but got there in the end. Hopefully they'll hold the engine nicely now.
Jimmy. |
25th Aug 2019 8:36pm |
Incidentally having done engine swaps (in a Defender which is far easier than a Disco) using a 3 tonne digger, fork-lift, engine-crane and chain hoist I'd definitely vote for the chain hoist.
Much much more controllable than any of the other options. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
26th Aug 2019 12:55pm |
