Home > Maintenance & Modifications > Cross Member bolts
Page 2 of 2 <12
ericvv
Just buy new genuine from Dan or from any JLR dealer, won’t cost an arm and a leg. Then install them using plenty of a good non-hardening anti-corrosion paste like Weicon. You will be good for many years.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #787932 20th Aug 2019 7:51pm
Grapax
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Alaska White
Thanks Ericvv
Post #787936 20th Aug 2019 8:08pm
Vitesse
I had the same issue. I just buy them from JLR and replace. quite cheap and you keep the original look. Plently of grease or coppaslip and all is well. I did pre empt this as I bought the car new and took all the factory bolts out at the back and greased them. so it wasnt an issue to change when eventually needed. yes, slightly OCD! Embarassed 2015 90 XS Santorini Black
Post #787950 20th Aug 2019 9:00pm
Grapax
Hi Vitesse do you happen to know the LR part number I need to order?
Post #787976 20th Aug 2019 10:43pm
ericvv
Part Nbr AYG100250 (M10 x 110)
And here is in my opinion the best non (= never) hardening anti corrosion paste to use liberally on your bolts (also door bolts, etc.). Believe in U.K. available from amazon.
Post #787986 21st Aug 2019 6:08am
Grapax
Thanks ericvv
Post #788016 21st Aug 2019 11:00am
Page 2 of 2 <12
