Home > Maintenance & Modifications > Cross Member bolts |
Just buy new genuine from Dan or from any JLR dealer, won’t cost an arm and a leg. Then install them using plenty of a good non-hardening anti-corrosion paste like Weicon. You will be good for many years.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
20th Aug 2019 6:51pm |
Grapax Member Since: 19 Nov 2016 Location: St Neots Posts: 77 |
Thanks Ericvv
20th Aug 2019 7:08pm |
Hi Vitesse do you happen to know the LR part number I need to order?
20th Aug 2019 9:43pm |
Part Nbr AYG100250 (M10 x 110)
And here is in my opinion the best non (= never) hardening anti corrosion paste to use liberally on your bolts (also door bolts, etc.). Believe in U.K. available from amazon. Click image to enlarge Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
21st Aug 2019 5:08am |
Thanks ericvv
21st Aug 2019 10:00am |
