Home > Wheels & Tyres > Free!...well tyres...just need your attention..not free.
All Terrain
United Kingdom 2004 Defender 110 Td5 XS DCPU Java Black
Ok having searched (and read) loads of posts on the forum re. tyre sizes and wheels I need to ask.....
Currently I have boost alloys with 235 85 16 Grabber TRs, if I change to 265 75 16 is this just a straight swap on these wheels with no danger of rub or funky tyre wear?
Often bump stop adjustment is mentioned, is this something a decent tyre fitting company would do as a matter of course or would I have to ask them to check them?
Please send any advice/insults my way! Confused
David.
Post #74061 3rd Jun 2011 8:09pm
fekete
You can fit them with no issues Thumbs Up
Try this out and it will give you a bit of an insight to what your changing to...
http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #74072 3rd Jun 2011 8:40pm
NoDo$h
2mm less diameter and yes, 5 minutes with a spanner to adust the steering stops. You may find, as I did, that the standard steering stop setting gave loads of room so I tweaked them a bit to improve the turning circle. Thumbs Up
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #74203 4th Jun 2011 12:09pm
Martin
Site Admin
It's not the bump stops which need adjustment, it's the steering stops Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #74207 4th Jun 2011 12:46pm
Lorryman100
And remember to leave 20mm clearance between the tyre and radius arm on full lock Thumbs Up
Post #74216 4th Jun 2011 2:40pm
All Terrain
Excellent, thanks for the advice everybody!
Sorry for the confused terminology!
Cheers,
David.
Post #74363 5th Jun 2011 8:20pm
All Terrain
Ok so got another question. Money is tight so is there any significant advantage going to the 265 size or should I just stick at 235 and be happy with the cash saving? Thinking of Discoverer STT, BFG MT, or similar? Prices seem to be about £20 a corner less in the 235 size.
Cheers,
David.
Post #74851 8th Jun 2011 5:06pm
BigMike
235 would be fine. hence landrovers specification of them Laughing
Post #74867 8th Jun 2011 6:36pm
CFB
265/75 just looks a bit more purposeful than the 235/85 I think, no other real benefit that I can think of although I guess the wider footprint could help on very soft ground or sand. Andy
Post #74872 8th Jun 2011 6:46pm
All Terrain
Good point Mike!
But I guess my vain side might prevail and as Andy says I'll end up going for the "more purposeful" look!
Thanks for the info gents.
David
Post #74884 8th Jun 2011 7:40pm
