![]() | Home > Wheels & Tyres > Free!...well tyres...just need your attention..not free. |
All Terrain Member Since: 22 May 2011 Location: Poole, Dorset Posts: 92 ![]() ![]() ![]() |
Ok having searched (and read) loads of posts on the forum re. tyre sizes and wheels I need to ask.....
Currently I have boost alloys with 235 85 16 Grabber TRs, if I change to 265 75 16 is this just a straight swap on these wheels with no danger of rub or funky tyre wear? Often bump stop adjustment is mentioned, is this something a decent tyre fitting company would do as a matter of course or would I have to ask them to check them? Please send any advice/insults my way! ![]() David. |
You can fit them with no issues
![]() Try this out and it will give you a bit of an insight to what your changing to... http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
2mm less diameter and yes, 5 minutes with a spanner to adust the steering stops. You may find, as I did, that the standard steering stop setting gave loads of room so I tweaked them a bit to improve the turning circle.
![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
It's not the bump stops which need adjustment, it's the steering stops
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
And remember to leave 20mm clearance between the tyre and radius arm on full lock
Excellent, thanks for the advice everybody!
Sorry for the confused terminology! Cheers, David. |
Ok so got another question. Money is tight so is there any significant advantage going to the 265 size or should I just stick at 235 and be happy with the cash saving? Thinking of Discoverer STT, BFG MT, or similar? Prices seem to be about £20 a corner less in the 235 size.
Cheers, David. |
235 would be fine. hence landrovers specification of them
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
265/75 just looks a bit more purposeful than the 235/85 I think, no other real benefit that I can think of although I guess the wider footprint could help on very soft ground or sand. Andy
Good point Mike!
But I guess my vain side might prevail and as Andy says I'll end up going for the "more purposeful" look! Thanks for the info gents. David |
