Home > Puma (Tdci) > Just DO it...
RED-DOT
Just DO it...
Whilst changing my wheels yesterday i decided to drain my fuel filter... the knurled nut was extemely stiff and i could see gunge dripping so i thought i would remove the filter to drain off the crud... big mistake, it was siezed on solid from over winter salt and had to destroy it to get it off. Unlike the TD5 filter it is not threaded but uses 3 lugs to twist on... once replaced my engine feels much livlier and idles much better. Winter seems to throw all sorts of crap around the filler and filter area and i will do it every Spring from now on... £49 for a tin can seems expensive though.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #73982 3rd Jun 2011 10:19am
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
How to you prime the system afterwards?
Jack
Post #73985 3rd Jun 2011 10:58am
RED-DOT
Easy, just fill a pint of diesel into the new filter, it doesn't spill. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #73998 3rd Jun 2011 1:02pm
Dave-H
Re: Just DO it...
Buy it from Ford .. its the same filter as the Transit uses [2 micron]
Only £29 Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #74079 3rd Jun 2011 9:04pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
just recieved this
http://www.duckworthparts.co.uk/land-rover..._Kits.html
add to that castrol magnatec, from tesco at £24 per 4 liters, and a full fluid and filter change with the best of kit for just over £120 Thumbs Up
Post #74143 4th Jun 2011 8:06am
RED-DOT
Good call.. RRP of diesel filter is £43+Vat.. duckworths seem to be quoting £28.28. Thumbs Up
Yip, fully synthetic Magnatec is on sale at Tescos for £24 and semi-synthetic at £20... which is best for Puma? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #74149 4th Jun 2011 8:13am
